550Gary
- Joined
- May 28, 2022
- Messages
- 18
- Location
- Tennessee
- Occupation
- Owner/Operator of custom Dozer Service
First, I would like to thank Heavy Equipment Forums.com for their site.
Second, Model 550G Dozer, serial # 7544458..(last six digits), Pedal Steer
Third, I highly recommend the TM140401 manual (complete) for any repairs. Mine copy is wore thin by all the use it has seen. However, it does not lay out the overall view of each component and their operation.
A little history: started having steering problems around 1 year ago.. My right side track had completely failed while traversing a hill. How I got up the hill to level ground is another story. After removing the back cover, the pressure hose to the Piston housing had broken off. The special shoulder bolt also on the Piston housing had been eaten down to a nub and the area (hole) it went in on the steering clutch was messed up. Both were repaired and reused.
I replaced the hose and fittings and thought it had fixed the problem….I did not dig any deeper into the steering clutch as I was unfamiliar (even after 30 years) with its internal workings. Even today, after much study and searching, I am not certain as to how it works.
From that time on, I had problems with the steering on the right side, not allowing the left side to move while holding down the right pedal. However, this too was intermittent allowing me to continue my daily task. Then one day, luckily while I was at home, the dozer got stuck in a place where it should not have, all accounting to the right side tracks failing to move when depressing the left pedal. While the right side pedal allowed the left track to move, it simply dug me deeper in the hole..,another story on getting it out.
Observations and repairs:
While holding the right pedal down, the left track will move with no problems….While holding down the left pedal, the right side will sometimes move but most of the time will not move.
I checked the pressure of the control value and got a reading of around 60-90 psi the left side and 140 psi for the right side… removing this valve, I inspected the spools and determined that either one or both of the housing and spools needed replacing due to thirty years of wear. Finding such parts are like pulling hen’s teeth. I did find a 450G pedal steer housing with spools. The spools were what appeared to be from a later serial number than my machine. I replaced the housing and checked the newer spools for PSI. What I got was a lower pressure as the spools were completely different that the originals….Since the housing was the same for all, I place the original spools into the housing with the following results. The right side had around 150 and slowly increased to 170psI. (180psi +/- 15psi). The left side increase a little to 120 psi. Yet this is not enough pressure to release the brakes on the right side when I depress the left pedal...I was back to square one...I then removed the rear cover and transmission (easy on the 550G) and found the hoses intact. However, the anchors on top of both brakes had moved from the center line of the steering drum.This no doubt contributes to the problems I am having but I do not understand how this brake system works with two phases (brake clutches within the drum itself and a brake belt around the outside of the drum that appears to be nothing but manual when ever a pedal is depress.) I have not check either of the drums for leakage nor have I removed them from the trans housing just in case I needed to revisit, trying to understand just what they are doing when I depress the pedal..I think this is paramount to fixing the problem.
I hope someone can understand this post and have some information that will lead tot he permnament repair of the problem. Thank you in advance.
550Gary
p.s. I do have pics of each steering clutch if needed.
550Gary
