Scott McFadden
Working on a 544G John Deere Loader that will not move in forward or reverse and the bucket controls do not work (no up, down, curl in or curl out.)
Unit does articulate (this is a separate hydraulic pump)
Drive shaft from engine to transmission is spinning. Driveshaft from transmission to gear front box is not spinning. Backed off parking brake and driveshaft still does not spin. I'm guessing fluid isn't passing through the pressure reducing valve manifold due to bad wiring/bad solenoids. Does anyone have information on what solenoid is for what? And what powers/grounds is needed to open the valve to allow hydraulic pressure to controls?
