My 580 SE has a filter light on the dash, that actually still works.
Why don’t you use the throttle stick to bring the RPMS into the suspect area and safely go underneath and also check every available surface for excessive heat build up.
That may indicate where the problem lies.
I‘m thinking pump, oil cooler lines, all cylinders and supply and return from filter along with filter housing.
