426 Series 11 won't move
Rick U
New Lothrop mi
I have a 426 Series II backhoe, 7BC-04514, that will not move forward or reverse. Neutralizer solenoid is working the way it should. My transmission is a 6Y-2598
The Pressure tests went as follows:
Forward and Reverse clutch pressure 130 PSI
Pump Pressure - 180 PSI
Zero Pressure on torque converter inlet and outlet at idle, high idle- 50 PSI
Lubrication and cooling 25 PSI at high idle. Zero at idle.
Does anyone know the correct PSI for each pressure tap I did above?
