351A Pete
Seller had a title, but is having to file for new because he can't find it. But I'm sure he will get it.
$6,500 minus the bed and hoist, which I didn't want. Supposedly it's been converted to 12V. I
have two choices for main box 9 or 10 speed, either one will work fine, but I also have a 8341G
auxiliary which is a progressive, gears evenly spaced, great for on road. But will only use direct
& overdrive with top direct gears of main box. Will repair interior, paint it, leave the 8V71 {has
jakes}, manual steering. want to keep it close to original with one stack.719188052_978292851471008_7700500153034068033_n.jpg719523657_996497219429486_9210514968922465286_n.jpg719612808_1483111356251880_571255892633135139_n.jpg720386565_1352873926721192_517308902841627916_n.jpg
Deere500a
Castro Valley ca
Sweet Pete .Suspension might be updated rubber block walking beam. Had a 64 351A old Pie rig turned into a poor dump truck used til 83 was parked got it 04 but needed work & 18' frame make a hoe hauler but CARB plans died( ended up scrapped in 22.
Can license with a collectors plate and liability insure with mileage capped at 5000 a year for
around $100 with State Farm. Just to get from show to show, which there are about six shows
within a radius that will only cover about 1,800 miles total.
Contacted Lavin, he has the old Pete micro phish build sheets.
Both boxes are overdrive giving it a total of .68 overdrive with both in top hole.
Rear drives are Rockwell SSHD's 6.14 ratio. With the heavy duty aluminum frame.
with 38,000 lb Hendrickson beam biscuit.
Truck was part of Redwood Construction Loggers fleet, and one of a total lot buy
of 20. California Oregon based.
I saw that same some years back, but what's interesting is those plus mine are
spec'd with one 5" stack, unlike most powered with 8V71's.
I will either change ring/pinions to 4.11 staying with the SSHD's or have double
overdrive boxes. If I change to 4.11's I can use a RT direct 9 or 10 and have the
overdrive in a .80 with the 8341G auxiliary and still have 67 mph top speed depending
on tire size.
I would like to keep close to original. Repainted same.
That is a sweet project. I had the ratio charts and remember the 8341 when I was dreaming of an MDT tow rig.
Yeah the 8341's were for 335 and down horsepower single counter shaft. Next was the
1241's rated for 400 horsepower/torque range after that came the 1750's for high torque
horsepower. Both 1241 & 1750 are twin counter shaft models, and can incorporate a PTO
Power Tower--as was called.
I may have missed it but is the jimmy staying or is it getting a cummins
Staying, or changed out to 8V71TA or 8V92. But it will be kept as close to original
as possible. Not many old long loggers showing up anymore to shows in oem
condition. Everyone is chopping the crap out of them or chromed overboard. But
I need to see just how good the engine is, I have some options of 8V71N's from
fire engines in real nice condition.
crane operator
sw missouri
Congratulations on the purchase. Going to have room in the shop where you used to work? Or going to have to find a different spot to work on it?
Every time I contemplate a project, I remember that all my bays are full of what pays the bills. I would have to rent a different place for a project.
Your area is certainly a advantage for rust free projects.
Tyler d4c
Salix Pa
Here in PA a truck that age was rotted to a pile of iron oxide 25 years before I was born
