west coast logging
I have a 345b 4ss
The engine won't go to 8 with the dial .
The monitor receives the signal and shows 10
In service mode I can get the machine to full throttle
In manual mode I can make hit full throttle
Service mode states dial is good and calibrated
The hydraulic restrictions light is on at the arm rest .
The boom drops fast inconsistent
The travel is also weak /inconsistent
I feel like the hydraulic tank restrictions is causing the throttle limit.
New filters all around
Ran machine for a few hours now problem beside lower throttle
Hydraulic filter housing was cold
They have what looks to be a priming pump /button on the bottom of hydraulic filters housing
I scanned for codes and had a speed sensor issue I repaired wires and set the depth correctly .
Rpm is reading correctly
No magnet controller installed
