joeRLI
Hi all,
Have a 333G skid steer serial #1T0333GМЕKЕ367896
Throwing errors codes 522446.05, 522447.05, 522448.05 and 522449.05
Unit will start, boom will raise/lower, but as soon as you try going forward or reverse, hydraulics lock out and can’t be unlocked.
Had Brandt tech come and check, his writeup is in the picture,
he ended suggesting issues with HCU, so we swapped that with our other 333G same year and the problem did not follow the HCU, and HCU from other machine did not fix the errors or cause any change.
This all happened in the middle of the machine running, hoping someone has some answers or can point is where to look
Thank you
Thank you
