Mechanic_Chick
I’ve got a 333E that we’ve been fighting a fuel issue on, but during diag of fuel issue accidentally shorted lift pump out against hydraulic cooler and now unit is a no crank no start. The keypad lights up when you press the start button, all leds prove out and then goes to backlight only, doesn’t respond when trying to start it, all fuses (that I can find) are good, I’ve been told there might be fusible links for ecm and starter but I have no wiring diagrams. Have codes out of ecu for 522597.09 TSC1 CAN message abnormal data rate; 237.31 vehicle id not available; 522596.09 can comm TSC1 abnormal data rate; 522618.09 EBC can message abnormal data rate; 522600.09 Y_EC can message abnormal data rate; 522619.09 Y_DPFIF can message abnormal data rate. Anyone have insight for me? Thank you!
