324 intake air sensor problems
Rajin Canajin
Lindsay
Have a 324k. At least that’s what we will go with til I can talk to mechanic, I’m nowhere near machine. The air sensor on top of engine cover keeps throwing a code 2630.00. Replaced sensor. Still code comes up. Any ideas?
And to add insult to injury, we had service advisor for the customer which was great for torque specs but let subscription run out and looking for something better. Does it need to be legal? Oh I don’t know. But it would be nice to have a wiring diagram. Thanks for any help.
Rajin Canajin
Lindsay
Thanks, I must have missed the Z. He says the code is there all the time. I don’t remember having to reset these. You fix the problem and it clears itself. Unless there is wires touching I don’t know what else it can be. I’m assuming this is all on can bus. He replaced the sensor. Didn’t change. Thanks for the help mg2631.
mg2361
Pennsylvania
Equipment Mechanic
Is the code active at start up? If it is, then there is most likely a wiring issue since you replaced the sensor. If the engine has to run a bit before the code pops up, then it would be the charge air cooler being plugged.
Rajin Canajin
Lindsay
Code is active at start up. Thanks for the help. Do you know what is a good diag tool other than ahem copies of service advisor or where you can get them?
Rajin Canajin
Lindsay
I have the volt meter. I actually want an amp clamp. But we have other stuff to diagnose and the customer service advisor was horrible. I needed a payload for a moisture meter for our 9670 and had to call the dealer. I know it’s their software and hardware but it’s a payload for a moisture meter. We are not reengineering the wheel. Just wondered if there was options. Jal test has called but they don’t have the how to fix it stuff which we used quite a bit.
mg2361
Pennsylvania
Equipment Mechanic
Only dealers can program controllers, for now. Which version of SA do you have. If I am not mistaken, there is a version with manuals only, and a version with full functionality except programming.
Rajin Canajin
Lindsay
I could do some fooling around. I think turbos and injectors. Very basic stuff. Couldn’t program anything. I think Deere is concerned about people deleting the power units. I honestly don’t know the version number. When I try to logon online it just sends me a nice message and saying not going to happen. So I want to either buy something else or get a funky version of service advisor.
