Urbanengineer
Hello all. Chasing an issue where I keep blowing Hydraulic Quick Coupler/Self Level fuses after a machine washing. Had a couple inches of dirt in the pan. Can't use the machine much at all without functional attachment pin control (hard to bypass too).
On this B series machine, the Quick Coupler Switch and Positive Self Level Switch are factory spliced together in the LH Panel Harness before the connection 12 for the upper platform Harness P-C2 (electrical diagram). I assume my issue is related to water in connector 12 or somewhere upstream from there. I cleaned (electrical parts spray and dielectric grease) random plugs I could easily find under the cab. I also cleaned up the connections at the back of the skid CONN 24, AKA (11) QCPL SOL [solenoid] and CONN 1 aka WC-C1. I haven't found this Upper Platform Harness Connection yet. Would appreciate help with that.
Circuit Upstream wiring code: 117-A77 YL -18
Possible Issue Connectors:
Conn 15 (117-A77 YL -18 A-C11 becomes 117-PA105 YL -18 PA-C14, have not id'ed), [
Fuse Block 1 (cleaned and greased), [accessible with cab down, cleaned and di-e greased all connectors and fuses]
Conn 12 (PA-C2 #3, have not id'ed says to see C-C21 (LOC SH 2 H-15) OR CN-C21 (LOC SH 2 H-11) ) [Shows at cab height at rear pivot of cab]
Conn 1 (cleaned and e greased),
ACPLR Sol Valve (S1, S2 Connectors (cleaned and e greased)
Any idea on what is going on here?
B Series Electrical System Schematic Part Number: 216-6423, Change:02 AND Media Number: RENR6419-06
