2017 John Deere 333g
Bogdan1995
Dalton ga
It won’t start! I can put it in ignition but when I press start nothing happens! The outside lights occasionally flash my buttons don’t work on the keyless start pad! The start/stop are the only two that work! Also have the STOP flashing! Any ideas what’s going on ?
mg2361
Pennsylvania
Equipment Mechanic
What is your battery voltage? Any wording in the monitor when the ignition is turned on, or is the monitor dead? Did you check all the fuses? Check to see if there is voltage to fuse F15 when the ignition is powered on.
Bogdan1995
Dalton ga
I disconnected all the plugs from my HCU and nothing changed! It’s like this module isn’t getting any power! Maybe bad ground idk
