Derrick Raney
2005 John Deere 200clc 6.8l 6068HT059 after running for hour to hour and a half excavator started to lose power under load. When this happens is I get out and check it has sucked the primer pump plunger down tight and the machine can’t get enough fuel under load. The longer it goes on the worse it gets. Fuel tank has been drained and cleaned, fuel line from tank to fuel water separator is just changed, fuel cap breather is clear, fuel filters are new, new injectors, injector pump, lift pump, new computer, new primer pump. As soon as excavator is turned off the primer pump starts to release. I can let the unit cool for and hour or so and start it back up and go back to digging and after 45 mins or so it will do the same thing.
