Hi guys I’m a new owner of an 1000hr cat 268B. It’s an older machine but it runs great. Has XPS aux hydraulics.
Here is my issue the secondary hydraulic circuit works fine with the buttons on the right joystick, however the primary (hi flow and standard flow) with the thumb wheel do not activate. This machine had the male dual flow connector ripped off and damaged, I replaced the hose, hardline, and dual flow aux connector today. I also tested the thumb wheel by backprobing pins 2 and 3 on the joystick harness. I’m getting a constant 7.82v regardless of thumb wheel position. Also my duty cycle readings just stay at 0% on my meter. I disassembled the hall sensor and attempted to use a neodymium magnet from an old HDD to test and still got the same readings... the oem magnet looks ok. I swapped the connectors on the solenoids and was able to get the circuit to activate using the secondary circuit buttons on the remote, so thinking my thumb wheel switch or aux ECM is toast. What are your thoughts? Nige hoping for a little assistance here before I shell out 1300$ for a joystick!!!
Thanks guys I appreciate your posts and have been reading them diligently.
