1993 John Deere 410D Constant hydraulic pressure
Carguts
Blacksburg, SC
Hello all,
Having hydraulic problems with a 1993 John Deere 410D serial number T0410DA792517. When I start the engine it cranks immediately, but after a few seconds it loads up the hydraulic system and stalls the engine. The only way to keep it running until it warms up is to continually use a hydraulic function (constantly raising and lowering the bucket or tilting and dumping the bucket). After it warms up for about 10-15 minutes it will run but you can tell it is still under load and will typically stall when putting it in gear unless you have it throttled up. All of the hydraulic functions are working and return to the neutral position when released. I have changed the screw on hydraulic filter with no improvement noted. The machine is new to me but sat for awhile due to a bad injection pump. I have an electric destroke valve, but from what I understand is that only works when trying to crank the machine, not after it is already running. Can someone give me some insight as to what relieves the hydraulic pressure in the system when no functions are being used? Any help would be greatly appreciated.
Thanks,
Alan
DustAndRay
USA
If you've checked all the external levers and pedals and confirmed they all return smoothly to the neutral position, but the problem persists, then the pump's internal compensator valve might be worth checking.
nikthewho
Delhi
Hydraulic Engineer
The hydraulics on a 410D should sit at high standby pressure with almost no flow when all spools are in neutral; your symptoms point to the main pump staying stroked (or a circuit effectively “open”) so the engine is dragging a heavy hydraulic load at all times.
You have a pressure‑compensated, closed‑center front pump. When all loader/hoe/steering/brake control valves are in neutral, the system works like this:
  • The pressure‑compensator and case‑drain valves on the pump sense outlet pressure and move the pump to minimum displacement (destroked), so there is almost no flow and only standby pressure on the lines.
  • All closed‑center spools block flow in neutral, so there is no return path to tank and the pump only maintains standby pressure, not continuous full‑flow.
Anything that prevents the pump from destroking (or that creates a permanent “open” path through a valve) will make the engine pull hard immediately after starting.
Likely causes for “loads up and stalls”​
With your description (stalls unless a function is held partly on, improves when warm), the most likely hydraulic‑side causes are:
  • Sticking or faulty pump compensator / stroke‑control section: If the compensator spool or crankcase relief in the pump head is stuck so the pump never fully destrokes, it will pump close to full flow against system pressure all the time, loading the engine heavily. Heat and thinner oil after 10–15 minutes can let a sticky spool move a bit, so the load “gets better” but never truly goes away.g-w
  • Control valve leak that effectively deadheads a circuit: A blown seal or internal leak across a section of the loader/backhoe valve stack can route oil so that one circuit is always seeing flow and pressure even with the lever in neutral, which makes the system behave as if a function is constantly held on and can stall the engine. This is consistent with the engine unloading slightly when you deliberately move a function (you are changing the path and pressure the pump sees).
  • Improper or non‑functioning de‑stroke / shutoff control: The electric destroke (or pump shutoff) solenoid is normally used only during cranking, but if it is mis‑wired, stuck, or the related test/shutoff plumbing has been modified by a previous owner, the pump can end up in an abnormal position (either never destroking or never fully upstroking). Some troubleshooting methods for these pumps involve temporarily bypassing or eliminating the shutoff/destroke solenoid, using a special Deere test plug; if that test hardware was left in incorrectly, the pump can stay in the wrong mode.
  • Contaminated oil or debris in compensator or valve: Machines that sat for a long time often have sludge or rust; debris can lodge in the stroke‑control/compensator or a small pilot orifice, so the pump sees the wrong signal and refuses to destroke until oil warms and thins.
(There can also be purely engine/fuel issues that cause bogging under load, but the fact that the engine is relieved when you move a hydraulic lever and that all functions feel normal strongly suggests the pump is the load.)
Given your experience level, the fastest way forward is to go straight to pressure checks and to the pump head:
  • Measure standby pressure and flow with all valves in neutral: On a healthy PC closed‑center system you should see near‑spec standby pressure (on Deere’s case‑study 410D, around 2750 psi) with almost no flow when all DCVs are in neutral. If you see substantial flow (gallons per minute) at neutral or a much lower “open‑center‑ish” pressure (for example 800–1500 psi with high flow), the pump is not destroking correctly or a valve is bleeding flow.g-w
  • Verify the electric destroke / shutoff circuit behavior: Confirm when the electric destroke solenoid is powered; it should only be energized during cranking to remove hydraulic load from the starter, then de‑energize so the pump can operate normally. If possible, temporarily disconnect or cap the shutoff/destroke control with the proper Deere test plug arrangement (as the Facebook 410 troubleshooting thread describes) to see if the pump behavior changes.
  • Inspect loader/hoe valve stack for a stuck section: Feel each section for abnormal heating at idle with all functions in neutral; a section that is significantly hotter can indicate continuous flow/pressure drop through that valve. If you crack a line on the suspect section while at idle and get continuous high‑flow oil with the lever in neutral, that valve is likely bypassing internally.
  • Check oil condition, suction strainers, and any charge/feeder pump: Given the machine sat with a bad injection pump, drain and inspect the hydraulic oil for sludge or metal, clean any reservoir suction screens, and verify any charge or transmission‑mounted pump feeding the front pump is clean and within pressure spec; poor charge pressure can also cause odd pump destroking behavior, although that more often shows up as weak/slow hydraulics rather than a constant heavy load.
If you share your standby pressure, flow reading at neutral, and any abnormal hot spots on the valve stack or pump head, it becomes much easier to pinpoint whether this is a compensator/stroke‑control issue in the pump or a valve section that is effectively deadheading a circuit.
