Treecutter16
Hello again, start with some background: our old D4H SN 9DB01545 was having trouble starting about a month ago when I needed it to pull a stuck truck out of the snow. Turns out it had ice in the fuel and blocked up the strainer. Cleaned that out and it started after a prime and ran for 5 mins shut off again, blocked up with ice again, must have been bad fuel, I added some fresh fuel and a bottle of Diesel treat and left it for a week or so. Tried again on a warm day well above freezing, It started and ran for long enough to pull out the truck that was stuck although ran weird and seemed to have low power I assumed there was still some water in the fuel working its way through but it kept running so I left it for a bit to charge the batteries and then it shut off on its own after about 15 minutes total run time. It wouldn't start again. I checked the strainer wasn't blocked, drained all the old fuel this time and replaced with new fuel to no avail. I replaced the fuel transfer pump still no luck. It appears the fuel makes it through every line up to the injector pump then hardly comes out the lines to the injectors. I also don't know how much pressure it should look like coming from the the transfer pump so maybe the pump is still bad or something else affecting that? It does have an oil leak that seemed to be getting worse but still had oil on the dipstick after it shut off, although substantially less than it had when I checked before trying to start it. It seems the lever going to throttle/fuel shut off to turn it off may have something loose inside that cover but I didn't open it as I cant tell if some springs will go flying and possibly cause harm for nothing.
I guess my questions are is it possible the oil leak is causing low oil pressure and not allowing the fuel to go past the injector pump? Could something inside the fuel shutoff have broke while it was running and shut it off, and can I open that cover where the lever goes in the governor to safely look? Or did running dry twice from the ice blockage cause just enough damage that it still started and ran for about 15 minutes before giving up?
Thanks for any info you can provide!
