AU.CASE
Hi all, long time no speak but at 1038 hours logged we decided to get stock in and full service overhaul of our dozer.
Having just cleaned our fire trails around the place here and shedded for a year before that, it has been time to solve a few minor and some larger problems where glands were leaking oil and dirt getting in, not cooling well, oil pressure meter problem, lighting kit upgrade, trans oil, hydraulic oil, leaking transmission control valve, faulty modulation filter (A50673), plus we now know the fluids were cheaper in January so that actually worked in our favour, for once.
Started by removing the tree pusher, this is a slip on, held by two 5/8 HT bolts through captive blocks in the rear pin of the angle cylinder piston shaft. Swap off takes about 20 minutes for single handed.
Tree pusher mounts here for correct track geometry and traction, this pin remains in place.
First off our new 44 of Mobil Delvac 30 to the engine, which wasn't really due but 'all fluids is all fluids.'
Donaldson filters were dearer, but CASE wanted six per retail sale? Huh?
