Coaldust
- Joined
- May 9, 2011
- Messages
- 6,057
- Location
- Subarctic Backwoods Trailer Park
- Occupation
- Big trucks is what I know. HAZMAT is what I tow.
Naw....it will run down the road just fine.....That's not an overload, just a driver too lazy to strap can to chassis. Hopefully there's a big machine on site to pick that can back on the rails.
True--but it's good for amusement.That's not an overload, just a driver too lazy to strap can to chassis. Hopefully there's a big machine on site to pick that can back on the rails.
It was overloaded before he tipped it and the bin came off the railsThat's not an overload, just a driver too lazy to strap can to chassis. Hopefully there's a big machine on site to pick that can back on the rails.
At the loves on HW 59 at cleveland texas there will be 4 or 5 of those trains blocking all the gas pumps. Not a license plate on anything.I see rigs like that come southbound through Texas. They are all headed for Mexico. You can usually find some kind of Mexican dealertplate on one of them.
Would even gold be a load for this?Saw fleets of These in SD. Maybe not overloaded But JEEZ!!
Not super singles but Duplex size tires.
Enough axles for about 380,000 lb ?Would even gold be a load for this?
If Look Closer, BOTH of those Side Dumps ARE Loaded, are trucking mixed soil to a Site where rock is separated out then hauled elsewhere. Wife Missed getting pic of that site. Company here uses Single Side Dumps similar just without the extra axles, routinely haul to 80/84,000 gw with them Filled, yet here are required to have rollover tarps.I just like the fact a Freightliner is latched to the kingpin and not a PacCar.![]()
What, you’ve never seen a Chevy towing a Ford before?!
I think GoodYear, Firestone, and Michelin had paid lobbyist's for that rule....Saw fleets of These in SD. Maybe not overloaded But JEEZ!!
Probably let too much cable out and bounced the can off the ground when trying to shake those last rocks out, no straps involved when trying to shake the can, ask me how I know that. Luckily when I did it was at the landfill and there was a big excavator there to scrape frozen crap from cans.It was overloaded before he tipped it and the bin came off the rails
That's good, if rules were followed, wouldn't need to enforce.Tried to play Commercial Zone card, Failed. Got to the level of measuring Bridge Formula, REGARDLESS total axle spread weight was outside bridge fornula. Licensed 80k but by formula only allowable to 71,500. That started the cascade. Short end dumps next and Quads as well All manner of rig set ups. ALL failed Bridge Formula as lengths shut it off.
Old Quads at previous employer are down to 67,800 scalable and the Tandem drop axle on that short end dump I used to drag, 73280 MAX regardless how many axles.
MO DOT Brownshirts have come to attention!!! Rules are Back On.
