Volvo penta help
tool_king
new jersey
road mechanic owner
Happy Easter guys
Would any one have to happen to have a pinout for the diagnostic connector on a Volvo Penta TAD1672VE serial 2016118015. Need to make up cable to be able to plug
in .Volvo is using a six pin Deutsch plug square plug as a connection mount on the left side of the engine .Any help would be great .Engine in mounted in scrap shredder. Unit has a 147 hours on it. Will shut does on a over heat issue .Radiator is not bubbling with compression getting to antifreeze. Radiator is clean along with intercooler and hydraulic cooler .Antifreeze is full.Hydraulic fan motor was replace with new oem from the factory do to seals blown out.
thank you
Ed
