tv370b case
rtd
ft worth
case tv370b i have a message on my screen that says operator not fully present and wont unlock so i can move the equipment I've checked the swing arm sensor the seat sensor what i have noticed, when you first get in equipment and seat down the screen powers up with out turning the key it does not do that anymore but it starts fine and screen comes on when key is turned on, checked fuses all good even bypass switch has anyone ever ran in to this problem
Arny L
canada
Try slamming yourself down harder in seat than normal, or pushing down harder on seat. the seat switch could be failing.
KSSS
Idaho
excavation
It is one of those sensors. You might also add the door sensor if you have an enclosed cab. Check the area where the lap bar makes contact with the sensor and clean it off.
