Your safety switches are all in series, to provided a ground for safety relay. Can you hear safety relay clicking when key is on, eng off, and operating lap, seat, or door switches. Relay should be with fuses I think. I can see that someone has changed the pilot block, by the coloured tie raps on hoses. Also your wiring doesn’t look very good, some open copper showing. If you’re hearing relay clicking then your switches are working, but you have to be seated, door closed, lap bar up and down. All three have to function.
