Hi, another Sullivan 375 question!
thought I’d see if anyone here might be able to give some help with a compressor issue I’m having. Recently bought a 2013 Sullivan D375 with just over 2000hrs. I serviced it when I bought (engine oil/filter, fuel filters, air filters, compressor oil/filter). this weekend after about 2hrs of blasting it shutdown on me. tmperature was good according to the gauge, about 170, plenty of fuel. I cranked it back up after about 5 minutes , had good oil pressure 50psi. Ran for a few minutes and shut down. attached is the code it was showing. Some googling showed “auxiliary shutdown switch” which could be low oil pressure, low coolant, low oil level. Does anything in that code pinpoint one of those? Was thinking it might just be a sensor? Has a John Deere 4045HF285 engine
Code is 0970.31.006
Code is 0970.31.006
