s130 bobcat acs 32-65 code
wayne weisflock
trent lakes ontario canada
I have 2005 S130 started off with different code last year now 32-65 and everything I tried checked all wires unplugged sensors and checked getting 5.1V at all sensors and two actuator plugs as well . today machine won't start check fuel shut off solenoid (which I replaced in Jan). That has failed again waiting on new one . But I don't know if I should order the acs controller ?? I took a picture of it P/N 6682422. Anyone know what else I should be looking for? I checked all fuses machine has only 1800 hours on it. turn key on 3 beeps the acs light on and the code
tool_king
new jersey
road mechanic owner
Whats you serial number and email so I can send you some stuff.
wayne weisflock
SORRY FOR delay I changed out acs controller and that fixed it. I have a 5600 toolcat shut it down and the next day won't move has code 50-56 can communication error. week earlier won't shift into hi-speed code was the front speed sensor. I checked fuses changed ignition fuse and blew again.
tool_king
new jersey
road mechanic owner
What is your serial number ?
tool_king
new jersey
road mechanic owner
That code is for a speed limiter I beleave .Whats your email ?
