Rexworks Biogrind 175--Cummins 4bt, runs for 30 secs then dies.
JacksonEquipserv88
Georgia
Machine runs fine, and starts right back up, but it has an older murphy system in it with all analog gauges, its definitely a safety of some sort shutting it down, anyone have any tips tricks to eliminate/pinpoint what it is? I would have figured there would be a blink code system or something on the machine...
Old Doug
Mo
You have probably check the fluid levels . Maybe put a mechanical oil gauge on it to see if you have oil presser . If it has a coolant level sender take it out and clean it .
