Monkeywithawrench
2016 Mack GU713 truck with Mack MP8 engine. SCR fault coming on. DEF pump not able to build pressure. 180,000M on the truck.
When this first started a month ago I ran some tests. I have Mack PTT, the licensed version through Mack. The line set coming off the DEF tank going to the pump has push to connect fittings on it. I disconnected the supply line and ran 3/8" clear tube from the header to the pump. Priming the system and connecting the clear tube to the header and the pump inlet, the truck ran fine. Built pressure to 130psi, no problems. Had them run the truck for a week with the clear tube connected to the tank header unit and the pump. No issues. Ordered a new line set, thinking it was the O rings that might be worn out. That was $800. Ran fine until last week.
Truck shows up with SCR fault. Going into Derate. Ran DEF pump test, not able to build pressure. Ordered new Bosch DEF pump from Diesel world or something like that. Mack wanted $2800. New pump for $830, then we overnighted it in........more money. Still not working correctly.
-with 3/8" clear tube connected to header and pump.........not seeing bubbles (air leak) coming from suction side of header.
-When I prime DEF pump, with clear tube........it is able to build pressure.
-Pulled DEF doser nozzle and checked for leaking doser valve-no leaks. Doser nozzle spray pattern correct, doser nozzle putting out proper volume as measured with cup.
-AFTER pump builds pressure-shutting system down, DEF pump does pullback-not able to build pressure again. Pressure builds to 30-40psi, then loses prime........it's seems the pump (the new one.........and the old one) aren't able to draw enough volume to clear the air out. I have run pressure test build up with the return line disconnected. No obstruction in the return line going into the DEF tank header return port. They are new lines, so not obstructed. New pump as of yesterday.....so that should be good.
BOSCH PUMP #21577511
I looked online for 'Theory of operation' for the Bosch DEF pumps but can't find anything. TOTALLY AT A LOSS FOR WHAT IS CAUSING THIS!! FRUSTRATED!!!
Wondering is anyone has run into this before and has some guidance.
Thank you!!
Thank you!!
