leeboy 8515 track wont go forward
808paver
hawaii
our leeboy 8515 paver went down mid job, the right track wont go forward, but has no problem going in reverse. the left track works fine forward and reverse. a hydraulic mechanic came to look at it but couldnt figure it out. any ideas?? all help is appreciated!!
blacktopper
Indiana
808, I am new to this board and came across your thread. did you figure out your issue? Im interested because we have blaw know 1510 which is basically the same machine. always looking for info to keep these machines moving. thanks
Vetech63
Oklahoma
Check 2 things. The front idler of the non working track. They do fail and can bind the rail into the frame. Also I have had the torque hubs fail. You can attempt to check the oil in the hub, but it's a bitch. The torque hub is a very common failure in the leeboy pavers.
  • Like
Reactions: DB2
Ryan Reed
Jamestown,TN 38556
HELP!!! Did you figure this problem out? I'm going through same thing
Vetech63
Oklahoma
There is a optimization and calibration procedure for the plus 1 drive system. Is there a status light on the dash and is it blinking?
bkmech
Pa.
Well if it’s an early 8515 then it’s Mc 200 later 8515s had plus 1 ether way check traction lever potentiometer drive gears. If they are alll plastic it’s early style they split throwing off parameters set up when optimizing
