Gehl CTL80 no crank
James alex zheltonoga
I sat in my Gehl CTL80 and it started right up. Then i shut it off to change the bucket and when i went to start it back up it would not crank and battery lamp was blinking in the cluster. Tested battery and it has plenty of power. Any one have any ideas what to start checking?
Vetech63
Check the safety stuff first......the seat switch and the lap bar switch. If those don't close the circuit the starter will not engage. Some systems also use the seat belt with a switch.
heymccall
The seat switch and safety bar do NOT prevent cranking.
Attached is the schematic.
  • TL150 Electrical.pdf
