Hello All
I have an old 2300 ditch witch with 2" chain with 4-pitch links set up for the standard 4" width trench. There are 17 teeth on the chain. I want to widen the trenches to 12". Ditch witch make tooth spacers that go up to 16". From what I have seen on google images some chains appear to have three full 12" wide spacers preceded by three 8" or 10" wide spacers. Does anyone know the correct configuration for the spacers? Is there a recommended arrangement for the teeth when going to the tooth spacers?
Should it be something like four sets of the following
Left tooth mounted internal
Right tooth mounted internal
Left tooth mounted external
Right tooth mounted external
Left and right tooth mounted on 8" spacer
Left and right tooth mounted on 12" spacer
Regards
Phil
Regards
Phil
