.RC.
So I have come to the conclusion my D6D has a cooling problem. It is not a dire cooling problem but it renders the machine unusable for longer periods in summer. The problem is I am pretty sure not in the transmission as it never gets any further then 3/4 of the way through the green, even when the engine reaches the red. The engine will not start running hot until the torque converter gets at least 1/3rd into the green which takes an hour or more. Then if I load the engine up, the temperature it will slowly creep up to the red.
It has done this ever since I bought it a couple of years ago. If I look at the machine I can see the following has been replaced. Transmission water cooler and the transmission radiator cooler, the fan belts are tight and the pulleys are new. The water pump also lacks paint so I suspect it also is new. I pulled the thermostat and checked it and it is fine. The only thing not checked in the engine timing, which I have heard can cause heating issues.
Which leads me to think I know what the problem is. The radiator core which has also recently been replaced. I have flushed it and washed it to no avail, however what I noticed is that the core they used has mighty big gaps between the fins so I looked up the core details which led me to an Australian manufacturer of cores and they list this core as having 6.5 fins per inch, while nearly every other radiator core they make for cat machines lists 9 fins per inch and they list a lot of cores.
So does is sound feasible that they installed a core that the manufacturer puts in the incorrect number of fins for the application, most of the air getting blown through does nothing as it goes no where near the fins.
The core is a 4N6298
