.RC.
Is it possible to reassemble brakes on a D4D just using the three small access holes?
I broke the rear band section, so I managed to undo the bank just using the access holes, and remove the broken band... I have the replacement here and can get it in OK, but I cannot seem to rotate it around to bolt it together again..
So is it possible in some way or does that huge cover have to come off which turns it into a pretty major job for something as simple as fixing a brake... Yes the manual says remove the cover..
