Jeffrey Bandel
2013 CAT0299DLGTC00836
I have a 2475-3 code. The bucket tilts up and down but won't raise or lower. If you try to pull back on the right joystick it makes a clunk sound and then won't do anything. If you shut the machine off and turn back on you can tilt it up and down but as soon as you pull back you lose everything.
I went through all the diagnostic steps in the CAT manual and all passed but the duty cycle test. With the key one I get around 500hz in the neutral position and 500 in the tilt up and tilt down position. In the forward lower position, I get 500hz. When I pull back to raise the bucket I get 0hz in any position.
The manual says the sensor failed and I need a new joystick. Before I drop another $1,700 for a joystick, I wonder if anyone has repaired one? Any other suggestions?
