Bobcat S250 Drive Noise
EZ-Man86
Vermont
Hey guys, Was running my S250 a while ago and it started a "clacking" kinda sound whenever left stick was engaged..
Also noticeable power loss on that side.
Ideas on what to look at? I have the cab off right now doing a swap so anything else maintenance I should do while in there I am all ears.
Thanks a bunch
EZ
Coaldust
North of the 60
I can hear it, too. It sounds expensive. Jack the left side off the ground and check for movement. You are allowed 1.5”. That will give you an idea of drive chain condition. Then, you can go from there. Let us know.
Broken axle hub, failed bearing, drive motor is toast,……. $$$$$$ oh’ boy.
EZ-Man86
Vermont
Lol thanks for the non-Inflammatory prognostication.
I have all 4 wheels off and sitting on blocks.. Can not get much if any movement out of the hubs.. Will put a couple wheels back on and let you know what I get.
EZ
Coaldust
North of the 60
The next easy check is to remove the left side drive motor case drain filter and see if the canister is full of junk.
Coaldust
North of the 60
Roger that. Be prepared to make a mess. I’d have a new filter handy in case you wish to replace it.
USA
Just remember some of those case drains, depending on model, returns directly to the reservoir. Which means before you remove it you should drain the reservoir or expect to have several gals of hydro filling your chassis.
-as for the clicking, most likely the chains, sprockets, and bearings. The power loss could be drive blew a seal.
EZ-Man86
Vermont
So I have next to no play in the wheels.. Got my hydraulic oil drained and lines removed from my case drain filter.. Off to get some crows foot wrenches so I can get the filter out.
EZ
EZ-Man86
Vermont
Well... Got my filter out... Full of silver shiny flakes and particulate... Assume its safe to surmise my drive motor is toast? Right hand filter is squeaky clean..
EZ
IceHole
AK
From mammary, there's just 1 case filter, both drives hook into it.
Mine was clean with ~5000hrs on the machine.
EZ-Man86
Vermont
So yeah i realized that both final drive motors drain to the one filter.. also the case drain from the aux at the bucket goes through an identical filter before then also coming to the one with both drains from the finals.
Wondering what else to see before pulling motors?
EZ
EZ-Man86
Vermont
Is it strange that I don't have any debris in the case drain hose or fitting from my weak motor?
EZ
USA
There is no brass in the drives so I would say your hydrostatic pumps are shot. They are piston pumps with brass slippers on the end of pistons. Engine must be removed to replace. Sadly with that much debris your gear pumps are probably shot too.
Coaldust
North of the 60
Hopefully the case drain caught caught the major debtis before it had the chance to cycle through the pumps and the main filter on the return side, but yes. Go ahead and check it. You’ll be changing the hydraulic oil anyways, before this project is done.
