All to fix a park brake oil leak.
56wrench
alberta
If that’s the hyd charge pump or a trans lube pump i see, it may be a good idea to check it while you’re in there. Or maybe its just the lube distribution for the upper shaft
OzDozer
Perth, Western Australia.
Semi-Retired ..
That's the cleanest and sweetest-looking bevel gear compartment and gears I've ever seen.
Button it up again fast, before it gets some contamination in there!
Mobiltech
Sask.
Good time to check rod and main bearings too.
