299D Hydraulic Connections for Tilt
Jeffrey Bandel
Radford, Virginia
CAT0299DLGTC00836
I had to remove the hydraulic lines for the bucket tilt and didn't take good enough pictures. I cannot remember where the flow and return lines hook up to the manifold. Does anyone know?
Acoals
Wisconsin
Start the machine, and bump the control a little and see which hose has oil. If you bump the stick to the center, as in curling the bucket back, the line that sprays oil should connect to the lower, or piston end fitting on the cylinder. Maybe stick the ends in a bucket and have somebody hold them in so you don't get too much of a mess.
Acoals
Wisconsin
It isn't "flow and return" as such, because there is only flow when the control is activated. Return alternates depending on whether you are commanding curl up or curl down. When no operation is commanded via the control there is no flow.
