2007 Takeuchi TB 180 FR Boom will not raise and no sick movement!
aluminum man
nh
Hi All Purchased a 2007 Takeuchi TB 180 FR ser#17830770 Crawls and Blade raises and lowers.When trying to raise boom or operate any other functions get no response! Please Help!
heymccall
Western Pennsylvania
You'll have to tilt the cab.
One of the two circled solenoid coils is pilot lockout.Screenshot_20240310-140432_Drive.jpgScreenshot_20240310-135835_Drive.jpg
The connector with a gray wire and a black wire will be the one you're looking for. Does it have 12v on gray wire when armrest is down?
aluminum man
nh
Thank you very much Heymccall! Will start this project when it warms up a bit and stops raining! I live in NH! Really appreciate your reply back and Knowledge about the machine! I've been checking out your posts and it looks like you've had 4 of that model.
aluminum man
nh
Hey Heymccal Paul from NH The plunger switch is in place but there is something missing that goes on the end plunger rod. Item # 9 which is supposed to contact the plunger rod cannot be adjusted far enough out to make that rod move in! Could that be the issue?
aluminum man
nh
Hello Heymccall Took out my console on my TB 180 FR see how to replace my throttle actuator Because it was missing. Machine has been running with a lawn mower cable bolted to side of cab.Which works for now.All connections made up as found to console but when powered up only fuel gage reads nothing else lights up. Checked blue and white striped wires 3 ea on console connector and read 12 volts ea assume they power up console? Am I missing something?
