1985 Liebherr 612B Engine Removal
Jeffrey Bandel
Radford, Virginia
I have a 1985 Liebherr 612B Track Loader. The engine threw a rod threw the block. I need to remove the engine. Can anyone provide some pointers? I've pulled lots of car engines but nothing like this.
Try to find a service manual or talk to a dealer. A JD dealer may be of some help. JD sourced loaders from Liebherr for a few years.
OzDozer
Perth, Western Australia.
Semi-Retired ..
I have never heard of a Liebherr 612B crawler loader. Are you sure it's not an LR621B?
You can acquire the service manual for the LR621 from the site below. Wait for a few minutes and you get a popup offering a bigger discount on the purchase price.
You will need a pretty high lift setup that can lift over 2000lbs to probably 5 or 6 feet high. Do you have or can you build a mobile gantry crane?
Jeffrey Bandel
Radford, Virginia
I have that manual. It doesn't give any specifics on engine removal.
OzDozer
Semi-Retired ..
Well, if there's no specifics in the manual as regards engine removal, it will likely be because the engine removal is simple and straightforward, to anyone with a lick of mechanical knowledge.
Do you have any Liebherr dealers in your State that you could call and ask about the removal procedure?
