JD 6600 Shutle Problems
Mquinista
Europe
Hy gents,
Got a 12k H JD 6600, with a powerquad and 5 speed range TXM, as far as range module concerns no problem at all, same for 4 speed power shift.
Whatever goes wrong with it, its on the FWD/ RWD shutle. Specially FWD. It does not engage well, specially if clutch pedal is depressed.
RWD engages well either with clutch depressed or not.
Shutle lever is on right side, and park position on the range lever.
BTW, it quit starting from key. But after this situation started to come along. Of couse Starter is bypassed and tractor starts fine and runs fine, just this issue?
Gents got any idea to start digging?
Thanks
