drott 50
went back out today with the owner, and got a list of filters and such for him to get.
Hopefully I'll get back out there later in the week with fresh batteries, filters, and camera!
Does anyone have experience working on Drott 50?
the owner told me that the drive gears are all messed up. Not sure until I get it running again what the symptoms are.
would a hydraulic leak mess up the drive gears? There is a good sized leak in the main boom and he is trying to get someone
to weld it for him. because of the leak, the hydraulic tank is empty. would a leak, with low oil level affect the drive gears?
I am going to get a manual for this machine.
thanks
This is the best advise anyone can give you, stay away from a Drott. I have owned 5 of them in the last 12 years and they were my worst nightmare. If you were an old timer (like me and Willie) You MIGHT could get the engine going and keep the repairs up on it. They are not easy engines to learn how to work on. They will run away in a heartbeat
hydraulic leaks, be prepared to replace all the hoses and cylinders (lots of money)
final drive problems (these systems were not great when they were new. If its the pinon shaft, its not real bad to fix, but still hard to do. If the pillow block is worn out, they are like $900 each, if you can find them and it takes a BIGGGG press to change them)
track rollers, Im sure they are worn out and if you can find them, the bolts will break off, trying to remove them. Then you have to get a torch and blow them out, HUMMMMM
Track adjuster, Im sure the seals are shot and the guides are worn out, ole yea the idler is probrably shot
Sprocket, probrably worn out
Track, pins and bushings HUMMMM
Fuel tank, probrably full of rust
I could go on and on, but If he would give it to you, its about worth $2000 in scrap
If you want someone to give you bad memories, go for it
This is from a ex Drott owner, that was hardheaded and thought I was getting a deal
