What was being used before Talkie Tooters ?
Diamond Danebo
Northwest USA
Equipment operator
I’ve been kinda curious what form of electronic whistle control was out there before Rothenbuhler came into the scene. Do any of you guys know ?
Diamond Danebo
Northwest USA
Equipment operator
thanks guys I appreciate it . im more so looking for the early electric radio signal system. ive heard of a radio worn like a belt that had a button you pressed for whistle signals .just curious if there is any info on this type of stuff.
Jumbo
Black Diamond WA
retired
We went straight from a 16ga cord with what might be called a "clacker" with electric contacts. generally referred to as a bug. It operated an electric solenoid on an air line to the whistle. When it was steam, it was a wire stretched tight to a spring valve on the steam line going to the whistle. Talkie Tooters caame out in the early 60's. Weyerhaeuser Snoqualmie still had bugs and bug wire hanging on the side of several yarders because of various issues (Maintenance I can only assume) with the talkie tooter. talkie tooter was and is in my opinion not only foolproof but logger proof. So I can only assume the issues were bad maintenance.
Diamond Danebo
Northwest USA
Equipment operator
Thanks for that. Very cool, I especially like the logger proof part
Hallback
Aberdeen Wa.
Gyppo tower logger
There was a system used by Simpson that was a box worn on the belt as you describe. Dave Massingham still has a set.
lg junior
oregon
Electro-bug, I still have a set. I don't know if they predated the talkie tooter. They were pretty poor setup, always in the shop.
skadill
B.C. Canada
Have a set,with chargers,air chime.One still works,one is dead internally.Just a display piece in my basement logging museum.The antenna went through the belt( wire pic),the screw off cap is the charger,the two black buttons held at the same time send the signal.Related to topic here,but not the original answer,just a different version.IMG_1788.JPG IMG_1789.JPG IMG_1790.JPG IMG_1791.JPG pic)
Tugger2
British Columbia
I remember Talky Tooters from my choker setting days.There was always a few coils of whistle wire around just in case,but i never saw it used . The last i saw of the whistle wire was being used on some haywire electrical stuff ,wiring trucks and machines ect .Before that was the Jerkwire as the old timers from the steam days called it .It was an art for the whistlepunk to string it out tight on branches and over logs to keep it tight enough to work the steam whistle.
Born2clearcut
Sunshine Coast B C
W
Have a set,with chargers,air chime.One still works,one is dead internally.Just a display piece in my basement logging museum.The antenna went through the belt( wire pic),the screw off cap is the charger,the two black buttons held at the same time send the signal.Related to topic here,but not the original answer,just a different version.View attachment 186476 View attachment 186477 View attachment 186478 View attachment 186479 pic)
We use to call these "Banana Belts " . Horrible things to wear when you had a fall they would drive into your side and hip bone. They were also very unreliable many times I blew stop and nothing would happen not good when getting near the block at the backend. One place I was pulling rigging we used a bunch of extension cords that ran from the tower out into the bush with bare wires at the bush end touch the wires together to blow whistle. It was interesting to say least. Good times were had by all lol .
