Volvo L110H
JPSR
Yorkshire
Hi all got a people with machine I’ve got no/limited fan, basically I’ve got 200-300rpm fan speed which isn’t enough anyway but then hit the brakes 2 or 3 times fan completely stops? Could this be a priority valve issue just always prioritising brakes? The system has 160bar pressure and press the brakes it holds pressure at 100bar
Thanks in advance
8V71
Fresno CA
After brake system changes to 160bar shut machine down view brake pressure in monitor or gauge key on engine off press brakes fully then release if you can only get 1or2 brake applications before it drops below brake change cut in pressure you may have a failed brake accumulator. Very common on that machine. Constant brake system charging demands all the P3 flow and deprives flow to fan motor. It could be several other things but accumulator test is where I always started.
