Volvo Ec290BLC Won’t rev up
Fastnet
Hello
We have a Volvo 29 ton excavator with a D7 engine I believe
Middle of shift it just lost power
It starts and idles for a bit but when you go to rev it up it’s like it’s starved for diesel and cuts out
The odd time it won’t even idle it just starts and cuts out
But it starts everytime as normal
Replaced the Low pressure pump driven by fan the belt
Replaced the two high pressure pumps
The Fuel control valve
Rail sensor
Pressure sensor
Swapped injectors from another motor
Still doing the exact same thing
The fault on Techtool is
psid 96 rail pressure system fmi 12
Would appreciate any help or advice
funwithfuel
Will county Illinois
Mechanic
So, to be clear, you have a 290BLc tier III? You've replaced everything? Did you inspect your fuel water separator? Is it a factory Volvo filter? Is the bowl sucking air? Which filter head do you have on the separator? Is it the piston pump that unscrews or the diaphragm plunger?
Oğuzhan.kocer
Turkey
Proboby your problem is electirical, control alternator if you have a change replaced the alternator and test machine again.
