truck and trailer tipped over:
(its open on the picture but that can be forced open in the fall)or if you look at the picture of the cylinder it looks twisted in the joint that is broken so maybe thats the reason
red arrow shows the shows the tailgate.............:beatsme
Thanks for the red arrow tonka... but I could see the gate was open form the
previous pictures. And I agree with grunk36
If the tailgate wasn't open when the load was raised to dump, would that
necessarily tip the truck over? I know that the material would start spilling over the sides, and maybe cause an uneven weight distribution from side to side... which could cause a tip.
This might be a more likely scenario... it looks like the lift cylinder tore away from the left mount on the box. That could cause the box to fall some what and be forced and twisted to the left by the remaining mount that was still connected on the right.
Actually, the cylinder started pushing and twisting the box to the left... and shifting the material that way too. Eventually, the load was so uneven, it
bent the lift cylinder.
The truck was already past the point of no return, and when it hit, the cylinder detached from the right side mount.
What do you think???...:beatsme
OCR
