So, I was working on the electric brake system this morning. Only one of the four brake drums has a brake tensioner (left front). That one works.... Hooray! Well, it was pretty far out of adjustment. And the configuration of this trailer makes brake adjustment a PITA. It doesn't have axles... More of a walking beam suspension and the bar that the spindles are attached to pretty much obscure the brake adjustment hole.
I pulled the right front hub/drum assembly off by taking the spindle nut and removing the dual wheels as a unit.
All of the brake components (shoes, springs, brake lever, brake magnet, etc) have just been rolling around in the drum for... I don't know how long.
So I am planning on just replacing the entire brake assembly on this spindle as well as the two rear ones. Pretty sure that they are just standard 12 x 2 electric brake units... And I already have them for tomorrow.
But this seal (in the pic above) is pretty alien to me. The info in the pic is:
TROSTEL
F400-244-7.5
I cannot find or cross this.
I did find a PDF that lists the seal and these are the specs:
Shaft: 2.687
Bore: 4.003
Seal OD: 4.008
Width: .469
Lip mat: F
I guess that last is interpreted as "lip material: felt.
Maybe that is why I have decided that the trailer is from the late seventies.. When I think of fuzzy materials like felt it suede... I pretty much think disco era.
Also, there was an alternative part number (I think) on the chart. A87166.
I have not been able to use either set of numbers to find replacements.
To be honest, I did not find the specs before I got home and was able to look at PDF on a bigger screen. So my local seal suppliers don't have spec dimensions or alternative part number. I will give them the dimensions tomorrow and seal if they can come up with either a single or double lip spindle seal from that. But just in case they can't.... Thought that I would throw the info up on the forum.
