TL12 error code 612/1714
lmizell
pocahontas ar.
I have read up and checked the fuses with no success. Ran fine, but next time I started it, flashing caution light and no hydraulics (drive ir lift), with the respective error codes. I am dizzy from staring at the internet for clues so thought I would ask. I have been checking wiring for breaks or other, but nothing looks abnormal. Anyone fix this issue before?
lmizell
pocahontas ar.
I will use this info and look for this puppy and see if we can test it resp. Thank you so much!! This might give us a direction to persue.
lmizell
pocahontas ar.
I have snet requests to assist to Takeuchi and one response was that they have seen it as a software issue and suggest "hooking up" and refresh the software. I have pulled the only relay that I can find and will have it tested today and see if #1 mechanic says to do next (assuming it's good).
lmizell
pocahontas ar.
I did find a pair of wires chewed in half by a rat. I crimped them back together with no change, but makes me more convincexd that there are other wires chewed somewhere? (FWIW these blue and yellow wires went to a plug that went nowhere. )
