Dozer575's ultimate dozer
Hello, Dozer575.
Did you bother to check the specs of existing Cat models before you posted the above post?
If you want an 80,000# machine, why not buy a D8R or D8T, both around that weight or slightly above and with around 25 more horsepower than you specified.
The current D7R series 2 is a roughly 60,000# machine with around 240 horsepower. You want to add another 20,000# and only another 40 horsepower. That's the power of ONE D2 and the weight of about 3 1/2 D2's. Or, to put it another way, you want a D7 with the weight of a D8R and 20 less hp. That doesn't quite make sense to this little black duck.
OOOOPPPSSS!!!!!!!!!!!!!!!!!!!!!! Sorry!!!!!!!!!!!!!!!!!! I forgot - you don't like hi-sprocket drives, do you?
The current D7G series 2 is around 45,000# and about 200 hp. Would you REALLY want to add 35,000# and only another 80 hp?
Quote: "I'm with Pete, make it heavier by increasing all the material thickness, so it isn't so easy to bend if a branch hits it." Unquote.
Firstly, ROP didn't say, "Increase all the metal thicknesses." He said that he'd like to do away with all the plastic and replace it with metal to increase weight. And if anything gets bent by a tree branch, what was the operator doing at the time, catching 40 winks, or 'fiddling' while the tree attacked?
It is very difficult to design a dozer, or indeed any machine, so that it is all things to all users. For heavy bulk pushing, a dozer needs more weight up front than does one used mainly for trimmimg. Ditto with a dozer used mainly for ripping as the weight transfer that occurs as the load comes on the tracks greatly increases the machine's ability to put its grunt on the ground.
I have run the D7G series 1 and found it a good machine to run, a good pusher, stable and manoeverable, easy to control and dependable. I have not run the D7H or R so am unable to comment.
I spent 2 1/2 years on a wide Cat D5B with straight blade and ripper and found it to be a VERY good all-round machine, good at bulk pushing and great for trimming. That particular machine did have a somewhat heavier than standard ripper fitted which I have no doubt added to its performance. Maybe putting a Tier 3 or 4 engine into that machine would come close to the ultimate for me, at least in that size/weight range and for the work that I was doing with that machine, a mix of bulk pushing and fine trimming.
ROP's swivelling seat wouldn't go astray either and possibly hydrostatic drive as well. More replaceable bushes in blade push arms, etc., wouldn't be a bad idea either 'cos they DO wear out and get slack.
If the manufacturers are going to stay with inter-connected steering clutches and brakes, at least get them up to the sensitivity and controllability of the older separated clutch and brake systems. The inter-connected systems are easier on the operator over a day's work but I have yet to run one that was as easy to control or as accurate as the earlier separated systems. (Hey Bob, how about that? We agree twice in 24 hours.)
I'd probably think up some more if I didn't need to go to bed. Yes, Angela, even I need to sleep at least a little occasionally.
