robby
has been running great for years... had been sitting a few weeks and while working it we opened up the throttle from 3/4 to full (engine 170-degrees, oil pressure 70lbs)... Engine was fine for a minute and then died down to an idle quickly while billowing a thick cloud of black smoke.... the emergency trip is functional and in its proper place... moving it made no difference in running other than at shut-off position (killed it).... setting throttle at idle position helps alleviate smoke but still abnormal amount... a higher throttle position actually causes lower rpm and increased smoke... non-turbo engine.... seems like blower trouble (not enough air) but never had this prob before, not sure what it is.... air filters are oil bath and are not restricted. :Banghead any constructive ideas are welcome
