Andyinchville
- Joined
- Nov 24, 2006
- Messages
- 110
- Location
- Charlottesville, VA
- Occupation
- Lawn Maintenance / Property Development
HI All,
Recently bought a 1985 International S1900 box truck with a DT466 engine and a 5+2 drive train and I have a few questions that hopefully gurus here know about.
1) For some reason, the trans is hard to get into gears....
Years ago I had a 1981 Dodge Dually truck with a 4 speed that was hard to get into gear when the clutch grabbed at the very top of the pedal travel.....The solution to this was to manually adjust the linkage until the clucth grabbed closer to the mid point of pedal travel rather than towards the top....the truck shifted nicely then.
I am suspecting the same thing is happening now (i.e. this truck only engages the clutch towards the top of the pedal travel).
I have not been able to locate any info online abut how to adjust the linkage for this truck (I did run across lots of instructions about opening an inspection panel on the belhousing and removing a retainer and turning a "ring" to adjust the clutch BUT I can't help but think this is for "big" trucks and not my little medium duty with a synchronized tranny.....
Any ideas on how to adjust things so my clutch engages earlier in the pedal travel?
Why is it it that my previous truck acted that way and the solution was to make it grab earlier in the pedal travel....I 'm just truing to get my head around how the earlier engagement made getting into gears "easier"
2) I have a 2 speed rear in the truck and it seems to work....I am still getting used to it.
Is it possible to switch from high range to low range while at a standstill (say at a red light)
Not that I would want to, but is it possible to switch from low range to high range sitting at a light?
3) I am sometimes leery of using the 2 speed because I have read that it is possible to get stuck in neutral (is this only if the shift motor gives out and breaks?) or can this just happen?
4) What fluid goes in the tranny and what fluid goes in the rear with the 2 speed?
Thanks in advance for any and all help on this.
Andrew
Andrew
