older Skytrak 6042
wood 504
tennessee
All functions work normally except raising the boom will jump as your raising especially when low to the ground
pressures checked
all 4 of the cyl hold valves replaced
Any ideas????
crane operator
sw missouri
Could be binding on the heel pin or the cylinder pivot pins, most of those telehandlers don't see a grease gun much.
I rarely find the holding valves to be a problem. Mostly its piston seals.
The cylinder barrels/ piston seals could be worn, you could actually have a swollen spot in the barrel, where you commonly drive around with a load on. i.e. a bunk of plywood bouncing around on the forks while driving on a rough jobsite, can cause damage.
92U 3406
Western Canuckistan
Wrench Bender
Definitely try and get some grease into the boom pin and the lift cylinder pins first. It'll be the cheapest thing to try first.
wood 504
tennessee
Thank you for the reply and ideas! Cylinder pivot pins and bearings have been changed. Heel pins have been greased.
may have to pull cylinders and check the barrels and seals. will keep you posted
crane operator
sw missouri
Did it jump before you switched the check valves? Or only after they were changed?
Its possible you have air in the system, if its only after you changed the check valves.
wood 504
tennessee
No it was jumping before as to why the check valves was replaced per JLG advise.
