Old Poclain Excavator
Yupe2be
Colorado
digger dan
Hi Dan......I bought a Poclain lc80 that has a 6 cylinder Air cooled engine.....it runs well....but once the hydraulics gets warm every thing slows down or stops working well.....it you jerk the levers hard things respond...but has low power.......only the rotation works fairy normal.....I am thinking the pressure relief might be bad or set too low?.......any advice would be appreciated.....thanks John........
digger dan
Dan, are you still around on this old thread?
highspeedchase
Colorado
Diggerdan
I was Poclain Factory Rep for 22 years. Beginning 1969 Till 1991. I have some relief valves for older Poclain, HC300, GC120, LC80. Pump valve removal tools for the same models (note: you will not be able to remove the pump valves without these tools). Misc O Rings. If you need anything, please let me know.
Taking a shot in the dark, But Diggerdan if you are still following this thread, I would like to talk to you.
