New member from SC
dp200time?
Pageland SC
Can someone tell me the lock timing on a delphi dp200 injector pump. It's on a new holland lb110 backhoe. I have the # 1 cylinder tdc and marks on the other gears lined up but the ip shaft has not been locked. Tapered shaft no key. I have dial indicator. Just not quite sure of exact procedure or where to check lift. Thepumpguysc , I'm in pageland and would gladly ride your way if you could help. Thanks fellas!
