need help with asv pt 60 transmission delay
darren98
berkshires
Hi looking for suggestions for a 2008 asv pt 60 delay in travel. there is a delay when going from foward to reverse or reverse to foward. there is also a longer delay when trying to turn either direction from a stop. I heard there is an adjustment on pilot generation block and it may be bias one way. my other thought is it may be drive motor or pilot pressure is low. when machine is on 2 speed high range it still happens but not half as bad. is it correct that high and low range are on the same drive motor? Any thoughts are welcomed
Digdeep
Wisconsin
I think you may have low charge pressure. I remember seeing a thread on here a long time ago about something similar. I own a RC50, but haven't experienced this.
